• Now's your chance win big! Join our community and get entered to win a RTX 2060 GPU, plus more! Join here.
    Pi Cast Episode 3 streams live on Tuesday, August 4th at 2:30 pm ET (7:30 PM BST). Watch live right here!
    Catch Scharon on the Tom's Hardware Show live on Thursday, August 6th at 2:00 pm ET (7:00 PM BST). Click here!
Question How do I connect cooler master 3 pin fan plug to a 4 pin gigabyte sys_fan header?
25thfret
4
I have a Cooler Master TD500 case with 3 LED fans in it and I want to connect them to a Gigabyte B450m-ds3h motherboard. The Cooler Master case plug for the fans is a THICK 3 pin plug while the mobo header is 4 pins with a tab on one side. The plug does not fit unless you force it over the tab. I've tried that and the fans do not spin. The Cooler Master plug has "Gigabyte" written on it, but it just doesn't fit and the fans don't spin. Do I need another mobo?
RealBeast
It won't fit over the tab using the 3 pins?
