I don't know how to connect my Deepcool SC790 PWM fan hub's SATA power port to the 6 pin to SATA power port on my PSU. Normally one of the "ends" will have gold pins sticking out allowing the SATA connection to be made. However, since both my fan hub and the power supply's cable have the "holes" in them I can't figure out how to connect them. My fans connected to the PWM hub are not spinning because of this issue. Is there an adapter that will add the gold pins thus allowing the PWM fan hub to be connected to my power supply? I would prefer to have my case fans actually start spinning.
