R Raildog27 Reputable Jan 30, 2016 1 0 4,510 Jan 30, 2016 #1 I have an LG42LF5600 tv and a VSX-402 Pioneer tuner. How do I get them connected? Can it be done? 21 years seperate the two.
Solution kanewolf Jan 30, 2016 Your only audio output is the optical port. You will need an adapter like this -- http://www.amazon.com/Panlong-Optical-Toslink-Coaxial-Converter/dp/B00ANIIY9I/ref=sr_1_8?s=aht&ie=UTF8&qid=1454185967&sr=1-8 It supports both surround and stereo input to analog output.
P Paul NZ Polypheme Sep 15, 2014 20,774 3 61,010 Jan 30, 2016 #2 Looks like the pioneer has RCA connections on it. Thats probably the only way you can connect it Upvote 0 Downvote
kanewolf Titan Moderator May 29, 2013 38,666 3,813 156,790 Jan 30, 2016 Solution #3 Your only audio output is the optical port. You will need an adapter like this -- http://www.amazon.com/Panlong-Optical-Toslink-Coaxial-Converter/dp/B00ANIIY9I/ref=sr_1_8?s=aht&ie=UTF8&qid=1454185967&sr=1-8 It supports both surround and stereo input to analog output. Upvote 0 Downvote Solution
