Hi all,going by this image, i think i need some kind of wire to change the colours of the halo fans ?.
I have a remote control to change the colours that works
I have inserted the reset switch from motherboard to the rainbow box as shown in image
My motherboard has only got 4 pins for rgb but that's only for the cpu fan.
https://ibb.co/XzFQjgK
Also i noticed that there is a wire attached to the sata power switch on the box with 4 pin holes but one is covered.
What am trying to do is add my fans box to the motherboard if that's even possible ?.
ASUS PRIME B350-Plus Motherboard,
