Question How do I connect the front audio panel of my old chassis to my Asus Prime B350 Plus?
avada
7
Hi!
I tried anything I can think of but nothing seems to work. When I connect something to the FA nothing happens when I plug something in the headphone jack.
Only ground seems certain, otherwise I tried plugging L/L- R/R- into 5/6 and 9/10 respectively, then inverted, then only one of them into 5 and 9. But the connection to the jack is never sense. In the driver software, the front headphone always stays dimmed and doesn't do anything when I click on it.
I of course set the on-board audio to AC'97. (Not that the pins match the connectors even with this....)
I ran out of ideas...
I have this in the manual:
I have these plugs:
avada
7
I was hoping for a user's manual for the case. Guess that was asking too much from the Interwebz.
Anyway, I did find this post on another forum. Maybe it can help?
-Wolf sends
Ah, okay.
Well, that suggestion doesn't work either. Maybe the bios is crap. Or Asus' driver software.
avada
7
-Wolf sends
Huh... Just noticed that it started producing sound, but in parallel with the back socket. Not sure when it happened, because I think the last few times I only checked wether something pops up or the front socket becomes enabled in the driver software. I wonder if it still works after a reboot....
Seems like the mobo or the driver is buggy.
avada
7
If you're getting some sound, that's something. I'd probably go ahead and install the latest Audio Drivers again.
-Wolf sends
Well, what I figured out is that there's no sound when the output is set to 7.1. Otherwise I get sound on both jacks... Sensing connections don't work.
So I guess this is something. When I want to use my front jack I switch to stereo or some other.
