M MSA_F67 Commendable May 24, 2016 1 0 1,510 May 24, 2016 #1 how do i connect to I/O Assy Front 2USB/1394/AUD 139124 Rev:C HP from motherboard p5g41c-m lx
Solution C C Calvin7 May 24, 2016 2.2.4 Header Design http://www.formfactors.org/developer%5Cspecs%5Cfpio_design_guideline.pdf Motherboard has: 2 x USB connectors support additional 4 USB 2.0 ports -0- 1394 Firewire connectors 1 HD audio header You should check your motherboard manual for pinouts.
C Calvin7 Titan Feb 19, 2013 11,722 335 76,490 May 24, 2016 Solution #2 2.2.4 Header Design http://www.formfactors.org/developer%5Cspecs%5Cfpio_design_guideline.pdf Motherboard has: 2 x USB connectors support additional 4 USB 2.0 ports -0- 1394 Firewire connectors 1 HD audio header You should check your motherboard manual for pinouts. Upvote 0 Downvote Solution
