How do i connect wireless WiFi or Bluetooth speakers to a Sony portable blu Ray player
For this to work, your BD player must have an audio output - digital (optical, coax) or analogue (2xRCA, or 2.5mm). Depending on that, get a Bluetooth transmitter with matching input (digital or analogue), and pair it with your speakers. You'll need separate power socket for the BT transmitter.
WiFi cannot be used between the player and speaker.
If you want more detailed information, provide model number of the BD player.
