Question How do I control my rgb fans
Jan 6, 2020
I've just built a pc in the coolermaster q300p and i connected the 2 rgb fans and the rgb lighting on the top of the pc to a dongle which connected rgb to sata power, which the rgb is running fine but i dont know how to control the rgb, it doesn't even appear in gigabyte rgb fusion
Welcome to the forums!
If you've connected the inline RGB controller to the case and the PSU and fans as shown in your manual, step # 11, then the button atop the case will be the only way to change the RGB colors/settings. You can't do so with the board or via software.
