how do i convert my 3g usb modem into usb wifi adapter
khaledelwakeeldy
I have wired router with good internet speed connected to PC by Ethernet cable plugged in normal NIC, I am looking for using this internet on my smart phone. is it any idea able me to use my 3g usb modem to broadcast data from my PC ---
Internet------>wired Router------>desktop PC "has no wireless card"--------->3G USB modem------>all wireless devices
You just need to get a wireless router and plug it in to your wired router.
Internet------>wired Router------>Wireless Router------>all wireless devices
Most wireless routers will also have 4 ethernet ports that you can plug your desktop in to.
3g USB devices can not be converted into a WIFI hotspot or connection point. The 3g devices do not have the correct radio transceivers to do so. Sorry!
OriginalCadaver has the best and easiest solution to your problem.
