Here is my monitor, it's supposed to be 10bit.
http://www.newegg.com/Product/Product.aspx?Item=9SIA24G1ZP5925&cm_re=asus_4k_monitor-_-24-236-399-_-Product
YES, I have it plugged in with a display-port cable.
When i try to enable 10bit color in the Nvidia Control Panel for my GTX 980ti It shows only 8bit color, no 10bit option like there SHOULD be.
NO, You to NOT need a Quadro card, I've seen people qwith 970s enable 10bit color.
How do I enable 10bit color, thanks.
