How do i enable a disabled monitor?
mysteryguy58
So i disabled my monitor from the screen resolution menu, and i was wondoring how to enable it again. i have dual monitors, i just need to enable the second one
Make sure the monitor is plugged in with the cable, turn it on, rigth click on your desktop, click screen resolution, if you only see [1] monitor click detect, after that you should see [1] and [2] click [2] and click under multiple displays: extend these displays.
i tried that but the second monitor doesnt appear
i tried that but the monitor doesn't appear there
