Assuming you have windows vista or 7. Right click on the desktop, go to screen resolution. Click detect. You can also configure the monitors through the AMD Catalyst Control Panel or Nvidia control panel. If it finds the 2nd monitor it will have a drop down menu called Multiple Displays. Select "Extend these displays". That's the basic procedure, if that's not working, make sure your cables are connected securely.
