How do I find out what parts (mainly CPU and video cards) are compatible with my motherboard?
Mediic
[First post] I've been searching for hours, and I haven't gotten any closer to any answers. :/ I've been wanting to upgrade at least my CPU and video card, but I know that some motherboards have certain limitations (I recently upgraded RAM). I've also heard that if you upgrade either CPU or video cards (I believe CPU) that you need to upgrade power supply too? Not sure, but can anyone link me to any "system scanners to determine compatibility" things, or just simply link me to some Amazon links or something. (I'm also ok with buying external things) Specs: Windows 10, Acer Aspire ZC-700G, 8192MB RAM, Intel(R) Celeron(R) CPU N3150 @ 1.60GHz (4 CPUs), ~1.6GHz, Intel(R) HD Graphics (not sure why but i don't get any more info on this card). Thanks in advance, just tell me if you need more info, again this is my first post.
You would likely have to buy a whole new setup. i dont know your specs of your motherboard but it probably doesnt have much upgradability. So buying a new CPU and video card will need to be done including a new motherboard. Adding a dedicated graphics card will require a stronger Powersupply. I would start by understanding what your trying to achieve. If you can find the specs of your mobo, you can decide if you can upgrade the processor and what expandibility it has for a new GPU. Generally pre-built computers from stores dont allow a consumer to upgrade very much as they use bottom shelf brands with no customizable features.
I hate to burst your bubble, but your system has very, very limited upgrade options beyond what you've already done. The reason for that is the fact that your CPU (and by extension graphics processor) are soldered onto the motherboard of the system, making them impossible for regular people to replace, i.e. you need to be able to, errr, unsolder things. The only way to get better hardware is to get a whole new system, I'm afraid.
Dang.. Theres no way to buy things externally and disable the other one?
