Question How do I fix a network issue and other errors on the operating system ?
Aug 17, 2020
Hi everyone,
I have a windows 7 laptop, which recently started to behave wierd,
When I starts the computer, I get first of all a blue screen which desappers few moments after.
After this, I get some errors, one by one, of these EXE's:
winlogon.exe , userinit.exe, werFault.exe, synTPEnh.exe, avguirna.exe - software error
All of them telling that:
apphelp.dll { damaged image }
After all this, my internet connection is also damaged, WIFI and pyshical ethernet cable, both of them says "Identifing..." but the internet never works.
What Can I do ?
Lutfij
If your PSU isn't compromised and your storage drives are intact, then I'd suggest trying to reinstall the OS. You should backup any and/or all critical content before you proceed to reinstalling the OS.
Also, mind sharing the specs to your build/system and the age of the PSU?
Reactions: Phillip Corcoran
Sep 12, 2020
98
23
45
............which recently started...............What Can I do ?
Yours is clearly an OS problem so a System Restore is likely to fix things.
If you're not familiar with it then head over to Control Panel -> System -> System Protection (top-left) -> System Restore. Pick an available restore point that predates as closely as possible with the onset of your problem.
