Octopixel Jun 26, 2021 6 0 10 Sep 1, 2021 #1 It's Disk 3, and as you can see it has no partitions. It doesn't even let me make one or do anything to try and fix it.
Solution NightHawkRMX Sep 1, 2021 Try a different usb port or pc. If you continue to see that, drive is dead.
NightHawkRMX Titan Ambassador Jan 1, 2018 18,633 4,002 81,540 Sep 1, 2021 Solution #2 Try a different usb port or pc. If you continue to see that, drive is dead. Upvote 0 Downvote Solution
Octopixel Jun 26, 2021 6 0 10 Sep 1, 2021 #3 NightHawkRMX said: Try a different usb port or pc. If you continue to see that, drive is dead. Click to expand... Is there a way to fix it? Upvote 0 Downvote
USAFRet Titan Moderator Mar 16, 2013 179,750 22,086 184,590 Sep 1, 2021 #4 Octopixel said: Is there a way to fix it? Click to expand... Depends on how it is "dead", but probably not. Storage devices die. Flash drives more than most other types. Upvote 0 Downvote
