Question How do I fix my rgb fans Please Help Me!!!!
Jan 11, 2020
4
So I bought a new pc started it up and everything seemed fine until I turned the rgb fan light on the top, bottom and back ones are fine and work normally however the middle one is a different colour to the rest of them, mostly white with spots of different colours. Even when i turn the light off with the controller the middle one stays on. i hope someone can help me out
bioax
Upstanding
Nov 30, 2019
262
41
220
4
how do I put in an image?
You can take a picture with your phone, and upload it to Google Drive or any public cloud. Then, you can share the link.
Also, did you try the thing Ralston18 suggested. I agree with him that it would be good to try that. Also, try switching what port the possibly defective fan is plugged into and see if it still happens.
