How do I Fix "Reboot and Select proper Boot device or insert boot media in Selected boot device or press a key"
So I finished my build had Windows 7 and everything was going well, then I decided to upgrade to Windows 10, now every 20-30 minutes I'm on the computer I'm on the computer I get a black screen with white words that saying "Reboot and Select proper Boot device or insert boot media in Selected boot device or press a key"
I read that you have to go to the bios and switch the hard drive has main priority, I don't really know how to do that its kind of confusing, I'm not sure if I did it right, I posted pictures with the links below of my BIOS, just wondering if you guys could tell me which one to switch if I did it wrong. And I'd there another way to fix this? Like could I just reset my computer to factory settings and keep all files or fully factory reset ? My motherboard is
970A DS3P GIGABYTE Motherboard.
PICTURES
http://imgur.com/a/9KgjN
PICTURES
