How do i fix this headset problem?
babachicken
1,452
It may seem like a stupid problem.. but its a very irritating stupid problem. its happening right now infact.
here is the problem-http://i.imgur.com/XWMCV4a.jpg
my headset cable(cloth) keeps doing this it keeps twirling up and my old headset used to do this. it ended up breaking because of this. i dont want another casualty 🙁
You pull the cable high enough that the headphones are off the floor so they can spin until there is no torque left in the cable. At that point, the cable should be straight.
It twists onto itself because you keep torquing it in the same direction all the time most likely without realizing it. If you want to straighten it out, you have to "un-torque" the cable by hanging the headset from its cable, straightening the cable and letting it spin until it stops. That should keep it from twisting again until you put enough torque back in for it to start happening again, at which point you simply rinse and repeat, no miracle fix there.
so basically im supposed to just put my headset on the floor while my cable is holding it up?
like this?
http://i.imgur.com/9NtRaZ1.png
and let is hang over night?
im kind of confused
thank you i understand now the cable isn't twirling
