[SOLVED] How do I get Corsair rgb lights to work on aorus pro z390?
Jun 22, 2020
6
I have just completed my first pc build, hopefully i assembled it all correctly... my question is where do I plug in the 4 hole female connector to a header? I’m using an aorus z390 pro and a Corsair spec delta carbide. Thanks
GarrettL
Respectable
That’s smart of them to do considering what there iCUE software can do.
Verify it is 4 pins on the connector and not 3 pins. A 4 pin connector plugs into the 12 volt RGB header on your motherboard. You don’t need the Corsair iCUE software. It would conflict with Gigabytes RGB software.
If you use Gigabytes RGB software you should have control of them.
GarrettL
Respectable
