Seafireable Prominent Feb 13, 2020 7 1 515 Jan 20, 2021 #1 CPU - Z says my graphics card have different performance level, how do I get my GPU to use the Perf level Base or Boost? Thank you so much in advance
Solution popatim Jan 20, 2021 It's usually set to automatic so just using it will cause it to increase the clock speed. If you have a recent (last 5 years or so) your integrated GPU is more capable then a 710. Here's a quick comparison against an i5-6500 https://gpu.userbenchmark.com/Compa...s-Intel-HD-530-Desktop-Skylake/m77649vsm33102
popatim Titan Moderator Dec 2, 2009 39,134 1,041 136,890 Jan 20, 2021 Solution #2 It's usually set to automatic so just using it will cause it to increase the clock speed. If you have a recent (last 5 years or so) your integrated GPU is more capable then a 710. Here's a quick comparison against an i5-6500 https://gpu.userbenchmark.com/Compa...s-Intel-HD-530-Desktop-Skylake/m77649vsm33102 Upvote 1 Downvote Solution
Seafireable Prominent Feb 13, 2020 7 1 515 Jan 20, 2021 #3 Thank you for your answer Upvote 0 Downvote
