Have you found a solution to your displayport problem? Your monitor should have come with a Dual Link DVI-D cable, which there is no reason not to use, but if you converted it to G-sync, then displayport is your only option. Just make sure your Displayport cable supports the version needed (I'm not sure on requirements here, as far as the cable itself).
