How do I hide media player next to volume control?
pikaKipz
Commendable
Feb 23, 2016
13
I like the little volume bar that windows shows when you turn the volume up and down. What I dont like is the media player bar next to it. It appeared for the first time for me today.
Is there any way to remove this?
Heres what I mean: http://imgur.com/a/v3aMV
That would be groove. There aren't any options to change that in groove. the player lacks a lot of functions so I would use something else like Foobar and not get either popup (though volume one will show up if you use media buttons on keyboard).
Is there a way to delete Groove then? Or will that mess with my computer
just don't use it. its built into win 10 so i would guess that even if you removed it, win 10 would reinstall it.
Set another media player as default and ignore it... that is what I did.
you can go to settings/privacy/Background Apps and turn groove off there as I found it used to run in background and talk to Onedrive
Thing is, Im using Spotify and so that is my media player. I cant change that
Im listening to Spotify through Spotify. But I use my keyboard to adjust the volume (as in windows built in volume adjuster). Thats when the media player appears, whenever I turn the volume up or down.
Cheers for the link, will have a look into it.
what is your default media player in settings/system/default apps. If you change it away from groove, I doubt that pop up will happen when you use volume - I just tried and with foobar as default, i don't get an extra media bar.
I wish they had a media player toolbar like old windows used to, so much more useful than some pop up but then I guess pop up easier for touch screens, something I don't have. Can't we have both?
Tried with VLC, no use.
Also tried with Foobar, no use.
Latest posts
