How do I hook a 4 pin psu into a 8 pin atx
Nov 15, 2018
14
I have a evga 850 GQ psu, my motherboard is a Gigabyte GA-H110-D3A I'm trying to find out if I am able to use the extra 8 pin chord labeled cpu that came with the psu to power the motherboard atx.
A strong psu like the evga 850w will have two such cpu cables to handle some very strong motherboards that need two aux 8 pin connections.
In your case, you need to use only one of them.
Put the other aside along with the other unused cables in case you need them for a future upgrade.
Nov 15, 2018
14
My power supply only has a 24pin and a 4 pin.
Nov 15, 2018
14
I have a 4+4 with a 24 pin that can plug into the psu separate but the chords that are pre attached to the psu are only 24 pin and 4 pin.
Nov 15, 2018
14
Yes that's my question the separate wires that come with it labeled cpu and plug in separately.. I can use those to plug into the cpu? And sorry for my lack of knowledge on the subject this is my first build.
Nov 15, 2018
14
Okay and where do I plug it into the psu? There is different labels such as cpu 1 cpu 2 period 1 etc etc..
