G Gilbert Aguilar Reputable Mar 5, 2015 1 0 4,510 Mar 5, 2015 #1 Reciever to Altec lansing lucasfilm thx
Solution A A americanaudiophile Mar 6, 2015 The owners manual of the speakers does not make it clear if there is a digital audio input but there is a SPDIF input indicator and they mention something called a versajack so I think that one of the inputs will function as a coax digital input. Your receiver does have an optical digital output so you would use one if these: http://www.showmecables.com/product/Optical-to-Coaxial-Digital-Audio-Converter.aspx?utm_source=google&utm_medium=cse&utm_campaign=47-450-001&zmam=49733141&zmac=5&zmas=1&zmap=47-450-001&gclid=CPDKhr-nlMQCFUIR7AodmhwAiQ to convert to coax. The other way is to use 3 of these: http://www.crutchfield.com/p_142LOC80/Scosche-LOC80.html to convert the speaker level outputs of the JVC to line level so you can connect to...
A americanaudiophile Titan Aug 27, 2008 13,663 0 101,360 Mar 6, 2015 Solution #2 The owners manual of the speakers does not make it clear if there is a digital audio input but there is a SPDIF input indicator and they mention something called a versajack so I think that one of the inputs will function as a coax digital input. Your receiver does have an optical digital output so you would use one if these: http://www.showmecables.com/product/Optical-to-Coaxial-Digital-Audio-Converter.aspx?utm_source=google&utm_medium=cse&utm_campaign=47-450-001&zmam=49733141&zmac=5&zmas=1&zmap=47-450-001&gclid=CPDKhr-nlMQCFUIR7AodmhwAiQ to convert to coax. The other way is to use 3 of these: http://www.crutchfield.com/p_142LOC80/Scosche-LOC80.html to convert the speaker level outputs of the JVC to line level so you can connect to the analog inputs of the speaker system. You need one each for the L/R front, L/R surround and for the Center/Sub. Upvote 0 Downvote Solution
