D Dewayne25 Distinguished Mar 22, 2014 84 2 18,635 May 8, 2014 #1 I dont know where to put the radiater because on top theres a huge fan that came with the case do i take the fan off how would i do it?
Solution I I i7Baby May 8, 2014 Take the huge fan off. The spec - http://www.coolermaster-usa.com/product.php?product_id=2810 - says you acn mount 3 x 120mm fans on top. So your radiator will have the same spacing as two of those fans.
I i7Baby Titan BANNED Jul 25, 2012 44,080 2 106,960 May 8, 2014 Solution #2 Take the huge fan off. The spec - http://www.coolermaster-usa.com/product.php?product_id=2810 - says you acn mount 3 x 120mm fans on top. So your radiator will have the same spacing as two of those fans. Upvote 0 Downvote Solution
