CPU: Intel Core i5-4670K 3.4GHz Quad-Core Processor (£166.74 @ Aria PC)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler (£25.44 @ Aria PC)
Motherboard: MSI Z97 PC MATE ATX LGA1150 Motherboard (£64.74 @ Aria PC)
Memory: G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3-1600 Memory (£62.39 @ Aria PC)
Storage: Samsung 840 EVO 120GB 2.5" Solid State Drive (£54.95 @ Aria PC)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive (£40.39 @ Aria PC)
Video Card: Sapphire Radeon R9 280X 3GB Vapor-X Video Card (£189.59 @ Overclockers.co.uk)
Case: Cooler Master K280 ATX Mid Tower Case (£30.92 @ Scan.co.uk)
Power Supply: EVGA 600B 600W 80+ Bronze Certified ATX Power Supply (£46.09 @ Aria PC)
Optical Drive: Samsung SH-224DB/BEBE DVD/CD Writer (£10.46 @ Aria PC)
Total: £691.71
Generated by PCPartPicker 2015-01-08 22:24 GMT+0000
So for the compatibility section it says:
"* Some physical dimension restrictions cannot (yet) be automatically checked, such as cpu cooler / RAM clearance with modules using tall heat spreaders."
How do I know if my case is going to be able to fit everything in properly?
Total: £691.71
