Fatblabs Commendable Jun 29, 2021 302 14 1,695 Jul 4, 2021 #1 i got a ASUS PRIME Z590-V ATX, ARGB, 1GbE LAN, 2 PCIe x16, 3 PCIe x1, 4 SATA3, 3x M.2 SATA/PCIe motherboard
Solution USAFRet Jul 4, 2021 Fatblabs said: or i could use ethernet Click to expand... Yes. That is better, faster, more stable than any WiFi.
bignastyid Titan Moderator Jun 19, 2011 33,485 1,617 159,590 Jul 4, 2021 #2 That motherboard does not have built in wifi, so you'll need to add a wireless card. Upvote 1 Downvote
Fatblabs Commendable Jun 29, 2021 302 14 1,695 Jul 4, 2021 #3 bignastyid said: That motherboard does not have built in wifi, so you'll need to add a wireless card. Click to expand... or i could use ethernet Reactions: Alabalcho Upvote 0 Downvote
USAFRet Titan Moderator Mar 16, 2013 171,317 17,829 184,590 Jul 4, 2021 Solution #4 Fatblabs said: or i could use ethernet Click to expand... Yes. That is better, faster, more stable than any WiFi. Upvote 0 Downvote Solution
CountMike Titan Oct 31, 2015 33,759 3,144 147,990 Jul 5, 2021 #5 if WiFi is a must, there are many USB adapters, get one with an antenna. Upvote 0 Downvote
