How do I know if my power supply is compatible with my motherboard?
David Ralph
90
Okay, so I really want this graphics card, but I am pretty sure that I am going to need a new power supply to power it. I was thinking about maybe a Corsair 430 watt. But I need to know if there could be a problem with compatibility with my motherboard. the biggest problem is I don't know what my motherboard is! I bought it from BestBuy and it didn't say in the pc specs! All help appreciated.
Most motherboards are either micro-ATX or ATX, which any ATX power supply will work with. That said, if you can tell me the model of PC you bought from Best Buy, then I can probably find out what motherboard you have just to be sure.
On a side note, just to be sure you have enough power for your new video card, tell me what model you are thinking of getting so I can tell you if a 430W PSU is going to be enough. Some cards require more than that.
The AMD site for that card states that the minimum PSU required is a 500W, and a 600W if you intend to do Crossfire. I would suggest going with the 600W to give yourself a little room to grow in the case that you decide to upgrade some other components later on. Any ATX PSU should work, but I don't recommend going with the cheapest one you find because inferior parts used in cheaper PSUs can cause damage to your system if they fail. Read the article linked below for more information.
http://www.tomshardware.com/reviews/power-supply-psu-review,2916.html
