Turn off your PC, unplug everything, and take one of the side panels off the case and have a look at the PSU. If the model/wattage isn't emblazoned on the side of the unit, there will be sticker on it stating wattage etc.
Hi, what is the model of your power supply? Many 300W power supplies blow after drawing 200W. What is the exact model without me downloading some fishy file form a site I'm unfamiliar with?
Thanks for the imgur! Well, it's a power supply with zero known information on it, so by my standards it's probably a poor quality 200W unit. So @OP I would change it for something of quality.
According to the TH PSU tier rating, the 550W "second gen" version of that PSU is a tier 4, meaning:
"Built down to a low price. Not exactly the most stable units ever created. Very basic safety circuitry or even thin gauge wiring used. Not for gaming rigs or overclocking systems of any kind. Avoid unless your budget dictates your choice."
