GL9106 Commendable Jun 30, 2016 121 0 1,680 Jun 9, 2017 #1 I have the G11CD case and the interior is kind of like on of those early 2000s and how do I manage the cables in that case?
Solution V1ctor89 Jun 9, 2017 Try to group cables as well as you can and use zip ties. Try to get the cables away from fans.
V1ctor89 Distinguished Apr 17, 2010 374 0 19,160 Jun 9, 2017 Solution #2 Try to group cables as well as you can and use zip ties. Try to get the cables away from fans. Upvote 0 Downvote Solution
gareththegiant Honorable Dec 15, 2015 375 0 10,960 Jun 9, 2017 #3 you can also buy cable tie mounting points. these are sticky backed mounts that you can use to wrap a cable tie around. you can use them to help tidy cables. https://www.amazon.co.uk/Cable-Tie-Mounts-Mountings-Adhesive/dp/B01HR45KBA Upvote 0 Downvote
13thmonkey Titan Jan 10, 2006 24,790 350 75,790 Jun 9, 2017 #4 velcro straps, better than zip ties. Upvote 0 Downvote
