How do I plug in corsair 500r power button to motherboard
DevonDavis
So I'm having trouble figuring where to plug in the cables for tower into the motherboard. I connected the leds and usbs already but there doesn't seem to be a cable for the power button. Any help is much appreciated, motherboard is Asus P8B75-V ATX LGA1155
I assume your Case is a Carbide 500R series just like mine.. actually it was supposed to come with the Power Cable by default labeled as POWERSW or else.. the cable should be there
And this is your motherboard ?
http://imgur.com/a/8HDJT
You should connect your Corsair power cable here
http://imgur.com/a/4qsjP
Your case should come with these cables -
http://imgur.com/a/G2I7o
If they are nowhere to be found, you should ask for a refund or exchange the case...
Hope that helps
Hope that helps
