How do I power my fans?
aces19
816
I am new to computer building, and I am wondering how to connect the 4 of my case fans. They are connected to the 3 pin connectors in the fan hub. I have a phanteks enthoo luxe case. How do I power the fans?
There is also a cable that is hooked up to the hub and says it can be connected to the motherboard cpu_fan
Could I connect that cable?
Also, I don't see any molex connectors on my fan hub, unless I'm missing something.
Ok, thank you very much, I think I will plug into the cpu fan on the mobo.
Ok, if it doesn't have 2, what would I plug in? (just in case)
Below is a link to what my fan hub looks like
https://www.google.com/url?sa=i&rct=j&q=&esrc=s&source=images&cd=&cad=rja&uact=8&ved=0ahUKEwjM_7SsxtTKAhVHwj4KHSdUCaQQjRwIBw&url=http%3A%2F%2Fbenchmarkreviews.com%2F19262%2Fphanteks-enthoo-luxe-full-tower-case-review%2F5%2F&psig=AFQjCNEWt3Nxm8cUqiC_PR3m178dfPWQCw&ust=1454346847259002
Thanks again :)
Latest posts
