Static is a rather overrated threat so don't be TOO worried about it.
DON'T: Wear wool ( sweater, cardigans etc ) it'll generate static when it moves against synthetics ( polyester, polyester/cotton ).
Rub your feet excessively against a carpeted floor.
Work on a nylon or synthetic fabric covered surface-cotton is fine.
Basically, remember your school work and don't turn yourself into a vandergraff generator.
DO: Earth ( ground ) yourself every few minuets during the build, it's easy enough to do, just touch: A masonry wall, a water or gas pipe, a heating radiator, a metal AC or heating grille a plugged in and connected metal or metal cased appliance-it needs to be plugged in and the socket turned on, the appliance needs not be in use.
Unlike normal live electricity, static will discharge easily into any of the above and won't be effected by a painted surface or wallpaper.
A few hints to ease the build:
Work in a well lit area, natural light is best.
Work on a flat solidly supported surface, I use a table covered with a folded over cotton sheet which not only stops scratches but is good at catching dropped parts.
Work with the case on its side and the other side panel in place, remove it only when you're ready to install the PSU-with the case upright. 😉
Position the case cables so they're out of the way before installing the motherboard-that way you won't accidentally trap one between the motherboard and case or motherboard tray.
Use a good quality, magnetic screwdriver.
Use tweezers to connect the case front panel leads if they're separate rather than in a preconfigured block.
It's easier to install the motherboard with the CPU and cooler in place, the cooler gives you something chunky to hold-use it to support the weight while you push the motherboard home and through the case EM shield with your other hand.
That big 24 pin motherboard lead is usually tight, lubricate it with a little petroleum jelly first and support the motherboard with your fingertips .
Read the motherboard manual!
Don't bring food or drink into the area. While spills can be wiped or dabbed off with a cloth or paper towel and residue dabbed off with a damp cloth/towel, it's better not to spill in the first place.
Work at your own pace, one part/cable at a time and don't allow yourself to be interrupted, so allocate plenty of time and let everyone else in the place know not to disturb you.
Finally: DON'T PANIC! A first ever boot usually takes longer than normal and you may very well need to make some minor BIOS changes ( boot order for example ) before it'll start, run and begin the Windows install.
