How do I Remove my side panel of my pc?
Lolmaster3267
35
Seems like my left side panel is stuck.i have already built my pc now I want to remove th side panel so I could manage my cables
My pc case is a aerocool strike x advance
On the back there should be 2 screws for each side panel. You will unscrew them and then there should be a lip on the case side on the back where you removed the screws where you will pull on. The panel then should slide back maybe 1/2 an inch and then be able to be removed.
its pretty simple, i have the same case.
just grap the handle and pull it very hard.
it doesnt go off that easy.
sorry for my bad english btw
