P patriciagray Reputable Oct 15, 2014 1 0 4,510 Oct 15, 2014 #1 Computer is Windows 7 professional and is 64 bit. I always ran a Dos program on XP prof 32 bit-cannot run it on new computer. DOS program uses QA and Lotus.
Solution Eximo Oct 15, 2014 Yep, pretty much the only option is a VM running Windows XP, that way everything is the same. Look up Windows XP Mode for Windows 7. http://windows.microsoft.com/en-us/windows7/install-and-use-windows-xp-mode-in-windows-7 Other option would be DOSBox. http://www.dosbox.com/ Don't let the appearance that it is for gaming fool you. It can run a lot of DOS based applications.
COLGeek Cybernaut Moderator Apr 6, 2009 59,303 5,193 184,340 Oct 15, 2014 #2 DOS programs are typically 16-bit. What program(s) are you trying to run? Upvote 0 Downvote
Eximo Titan Ambassador May 27, 2010 28,306 5,734 144,340 Oct 15, 2014 Solution #3 Yep, pretty much the only option is a VM running Windows XP, that way everything is the same. Look up Windows XP Mode for Windows 7. http://windows.microsoft.com/en-us/windows7/install-and-use-windows-xp-mode-in-windows-7 Other option would be DOSBox. http://www.dosbox.com/ Don't let the appearance that it is for gaming fool you. It can run a lot of DOS based applications. Upvote 0 Downvote Solution
J Jos Schaars Honorable Jun 4, 2013 6 0 10,520 Oct 17, 2014 #4 Or you could try vDos (http://sourceforge.net/projects/vdos/). It does a far better job in emulating DOS for programs like QA and Lotus. Upvote 0 Downvote
