How do I run Skyrim in Ultra settings?
Moxy3D
37
Ok. I've been trying so hard to run Skyrim on Ultra settings with my system:
AMD Ryzen 5 1400
8GB RAM
Radeon RX 580 4GB
Window 10 64bit
Couldn't this setup work?
Thank you
-Bri
no it should 100% be able to run it.
But Skyrim isn't a well designed game, so it being old means it actually runs poorly, regardless of system power. And that's where modders have stepped in to fix many/most of it's problems that bethesda hasn't.
https://www.nexusmods.com/skyrim/mods/71214/?
Forgot to mention there are no additional mods added. We are talking about vanilla Skyrim here. Secondly, the resolution is set to 1024x768. This is a mid range system right?
So you're saying my system can't run this OLD game? Just tell me what needs to be replaced or upgraded.
Okay I am on the Nexus website and I see more than a few patches. After typing into the search trying to narrow down my choices, nothing pertaining to a sufficient patch came up. Is there a link to an example of what patch you are indicating?
Thank you
-Bri
https://www.nexusmods.com/skyrim/mods/19/?
https://www.nexusmods.com/skyrim/mods/23491/?
https://www.nexusmods.com/skyrim/mods/25127/?
After installing the individual mods, the following general load order needs to be followed:
Skyrim.esm
Update.esm
Unofficial Skyrim Patch.esp
Dawnguard.esm
Unofficial Dawnguard Patch.esp
Hearthfires.esm
Unofficial Hearthfire Patch.esp
Dragonborn.esm
Unofficial Dragonborn Patch.esp
[Your other ESM files]
HighResTexturePack01.esp
HighResTexturePack02.esp
HighResTexturePack03.esp
Unofficial High Resolution Patch.esp
[The rest of your mods]
Hmm. I installed the Unofficial patch since I dont have both DLCs. I am still having trouble running it in Ultra! Also a new issue: my GPU-z is showing the temp around 70-75c and flickering in game!
Tell me truthfully: Do I need to replace this card?
But the flickering in game? Showing a palette of textures? Also forgot to mention my PSU is 440w. I presume that's not enough to power this card?
Well the PSU in question is a EVGA 450W non-mod 80+ bronze. What do you recommend? I was thinking a Corsair 750W might be better for my card? However, wouldn't that mean I need to replace my heatsink with an aircooler?
Well, the reason I was thinking a 750W PSU is I also have Doom and GTA V which ive heard requires alot from the video card. Or would a 550W PSU suffice?
