M Muath_ Honorable Oct 18, 2015 305 0 10,780 May 31, 2016 #1 so I bought this case http://pcpartpicker.com/part/rosewill-case-srm01 it came with nothing to separate the mobo with the case, was this intended or should I contact the manufacturers? If it was intended how do I separate the mobo from my case?
Solution C C Calvin7 May 31, 2016 Normally, the case comes with a parts box tucked in the case somewhere. You need to use the standoffs to separate the case from the mobo. http://www.newegg.com/Product/Product.aspx?Item=9SIA9F93GK7366&Tpk=9SIA9F93GK7366 The pictures of the case at newegg do include standoffs, screws and owner manual. Washers are not normally needed.
Zerk2012 Titan Ambassador Oct 6, 2014 22,332 2,407 104,240 May 31, 2016 #2 Their screws holding the motherboard in the case. Upvote 0 Downvote
C Calvin7 Titan Feb 19, 2013 11,722 336 76,490 May 31, 2016 Solution #3 Normally, the case comes with a parts box tucked in the case somewhere. You need to use the standoffs to separate the case from the mobo. http://www.newegg.com/Product/Product.aspx?Item=9SIA9F93GK7366&Tpk=9SIA9F93GK7366 The pictures of the case at newegg do include standoffs, screws and owner manual. Washers are not normally needed. Upvote 0 Downvote Solution
