I recently purchased three Asus VG248QE monitors and want to use all three of their speakers at the same time. I have connected each monitor to my computer through DisplayPort (this is also how I will be connecting my speakers' audio).
Is there a way in Windows 8.1 to set the default audio output device to three DisplayPort-connected speakers?
(I was also skeptical about using a triple 3.5mm jack splitter because it seems that, when I connect a 3.5mm jack to the monitor while it's connected with a DisplayPort cable, the audio will not output through the 3.5mm jack - only through the DisplayPort.)
Thank you!
Thank you!
