To the opening page. As if I had clicked the icon to start Edge. The one with all the news and widgets on it.open to what page?
Thanks for the reply. No, not that. And the edge bar is not enabled. What I mean is that Edge (the full browser) opens when I boot my PC.Perhaps you're referring to the Edge Bar? Look in the Edge Settings for Edge Bar and ensure that it is deactivated.
WAG....is it in task scheduler?I don't see it in startup. Its not the browser I have set as my default browser. I use Firefox. This just started happening after one of the latest W10 updates.
Just checked. The only thing there pertaining to Edge is the Edge Updater, and it's been there from the start. That usually happens in the background when Windows does "Updates". Besides, this happens immediatly upon boot up. Not enough time for Update to have run. And it is a random thing... sometimes it happens, sometimes not.WAG....is it in task scheduler?
