Atlas06 May 14, 2021 2 1 15 May 14, 2021 #1 Hi, I’m going to look at some used Corsair fans today and the guy says they are rgb but I can’t see them lit up, just running. This seems a little sketchy to me, is there any way I can tell what model of fan it is or if it has rgb? Thanks!
Solution punkncat May 14, 2021 Look at the label on the fan and carry your phone. You will more than likely see not only the LED portion of the fan, but an additional cable for LED control might be in place as well.
punkncat Titan Ambassador Apr 3, 2018 13,376 3,801 70,890 May 14, 2021 Solution #2 Look at the label on the fan and carry your phone. You will more than likely see not only the LED portion of the fan, but an additional cable for LED control might be in place as well. Upvote 0 Downvote Solution
Atlas06 May 14, 2021 2 1 15 May 14, 2021 #3 punkncat said: Look at the label on the fan and carry your phone. You will more than likely see not only the LED portion of the fan, but an additional cable for LED control might be in place as well. Click to expand... Thanks, I appreciate the help and the quick response! Reactions: punkncat Upvote 0 Downvote
