How do I wire a cooler master hyper 212 when adding a second fan?
oldblackman
35
I will soon be building a pc with a cooler master hyper 212 evo and will be replacing one of my 120mm fans with a 140mm fan and adding two more 140s to the front for intake. I will use the 120 I take off the top (being replaced by the 140) and will install it at the back of the 212 evo for exhaust so it'll have the stock fan on the front (ram side) and the spare 120 on the rear. My question is how should I wire the two fans? Will they both somehow go to the cpu fan connector?
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor (Purchased For $215.00)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler (Purchased For $29.99)
Thermal Compound: Arctic Silver 5 High-Density Polysynthetic Silver 3.5g Thermal Paste (Purchased For $7.83)
Motherboard: ASRock Fatal1ty Z97 Killer ATX LGA1150 Motherboard (Purchased For $79.99)
Memory: G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3-2133 Memory (Purchased For $79.99)
Storage: Crucial MX100 256GB 2.5" Solid State Drive (Purchased For $104.99)
Video Card: MSI GeForce GTX 970 4GB Twin Frozr V Video Card ($349.99)
Case: NZXT S340 (Black) ATX Mid Tower Case (Purchased For $69.99)
Power Supply: EVGA 750W 80+ Gold Certified Fully-Modular ATX Power Supply ($119.99)
Wireless Network Adapter: TRENDnet TEW-805UB 802.11a/b/g/n/ac USB 3.0 Wi-Fi Adapter (Purchased For $29.99)
Case Fan: Rosewill RABF-131409 55.4 CFM 140mm Fan (Purchased For $7.99)
Other: Anti-Static Wrist Strap (Purchased For $5.00)
Total: $1116.72
Generated by PCPartPicker 2015-01-08 03:07 EST-0500
Not a good idea. Your CM 212 has an 82.9cfm 120mm fan and your NZXT case has a 45cfm fan. It would probably be worse for your cpu airflow than the single fan configuration.
