Sometime in the future, I'm looking to update my I5-4570 to an I5-7600K or I7-7700K, as well as getting a 1151 motherboard to go with it and a large full tower like the Corsair 750D to house it all. As it stands, I have a small mid tower case with only two case fans and a stock CPU cooler. While this is fine for the I5-4570, there's no way it'll accommodate a much more powerful CPU in terms of temp regulation.
So I'll be between air or liquid cooling for the revamped system. Since a $300 custom water loop I won't be able to assemble isn't really in the question, I'll be looking for a preassembled system. (Currently looking at a Corsair H105) If I go air cooled, it'll just be a standard CM 212 Heatsink and a bunch of fans.
In terms of the ability to cool and relative noise, what would be better, a liquid cooled system with, say, four case fans, or an air cooled system with maybe six case fans? If the case has 3x 120mm fan slots up top, will it fit a 240mm radiator up there?
Thanks so much!
Thanks so much!
