How do you change input settings on a monitor?
Marcusg0109
Ok, I'm trying to play my PS4 on an old monitor. I have all the needed cables to do so but when I go to play, the monitor tells me input signal out of range, change settings to 1280×1024 - 60Hz. How do I change these settings. The monitor is an HP L1910.
I've looked at the specs of your monitor, and... well, when the only models of it you can get on Amazon are refurbished, I think that that's a red flag. The problem is simply that your monitor cannot run the PS4. The monitor is not 60hz and its MAXIMUM resolution is 1280 x 1240. There is no way to solve this other than getting a new monitor (as far as I can tell).
