How do you connect a gpu\'s to your power supply
bahblissa227
8
well i get that u need a 4 to 8 pin connect but i mean i only have one 4 pin connecter and thats taken by the atx cpu plug in which idk what it does so idk if i should mess with that or get a new connecter to connect to my power supply
As ish416 said, they're molex adapters you could buy, but if your Power Supply didn't have the necessary connectors for a GPU, it means it can't support a GPU that requires those PCI-E 6 or 8 pin connectors.
Even if you get those adapters, your PSU may not support the video card itself and it could damage your hardware.
why would they have adapters if u cant connect it to ur psu anyways and mess everything up..?
No I meant that maybe your PSU can't handle that video card because it doesn't even have the appropriated connectors.
is it just the wattage bcuz its 400 and i got an 430 watt in a different computer. mb its 400 to but its a different brand idk :/
