How do you enable the boost clock for a GPU? (Zotac 980 Ti Amp! Extreme)
1-800-Get-Rags
42
I have SLI of these cards and I'm wondering how I enable the boost clock on them. I don't see that option in Firestorm. It is a switch on the card itself? Do I have to OC to that point manually?
No - it's automatic process. You don't have to do anything.
Just make sure temperatures are ok. If your cards are overheated, boost mode will not engage.
Thank you. In what situations will it enable itself? And what's the best way to check?
It will enable once your GPU is being put under load, when you're idle on your desktop nothing will happen.
