[SOLVED] How do you flash vBIOS using flash drive for Asus HD 7870 ?
Mar 4, 2021
hi i have a asus hd7870 and need to install the vBIOS for it to work and was wondering how do i do this ?
computer is a hp pa-2050a, 8gb ram with i3-2100 cpu amd a coolmaster 650w psu and i just want to play basic games like aoe4 and stuff but i dont have a clue how to do it using freedos. i have a 32gb usb drive and the rom needed to do it and have formated the drive to a bootable freedos format. any help would be great
EDITED:
In order to flash the VBIOS of a graphics card you need to use a software tool, no flash drive required.
Please try following this :
AMDVBFLASH for AMD gpus:
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&cad=rja&uact=8&ved=2ahUKEwiErL_glZjvAhXoct8KHeSlCNEQFjAAegQIBRAD&url=https://www.guru3d.com/files-details/amdvbflash-download.html&usg=AOvVaw0lR2Dj3CuYb6Hm2av6nYqm
And here's a tutorial for AMDVBFLASH:
View: https://youtu.be/VlGy_NWPFc4
You'll just need:
  1. The software tools,
  2. The ROM you plan to flash the card with
Please be sure to follow all instructions properly, you can brick the card if you flash the wrong BIOS on it.
EDITED:
You'll just need:
