How do you increase range of usb wifi adapter and external antenna?
primemods
Hello,
Is there are ways to boost signal range to access network for a decent range like half mile +? The current setup I have is a Alfa awus036h 1 watt wifi usb adapter with a yagi antenna 25dbi. Is there like wifi amplifier or something? Maybe upgrading to a more powerful usb wifi adapter? If so, which ones should I upgrade to?
Edit:
Not sure if these are better than my orginal setup? http://www.ebay.com/itm/High-Power-Long-Range-802-11-B-N-G-300M-USB-Wireless-Adapter-1000MW-Wifi-Network-/320961756367?pt=US_USB_Wi_Fi_Adapters_Dongles&hash=item4abacfbccf
Thanks!
It extends your current wifi setup. And, as mentioned, there are much less expensive options, but it sounds like you might need something more powerful like the link.
What about something like this? Will it do the same? http://www.ebay.com/itm/200819031289
Latest posts
