How do you mount Thermaltake 120mm Riing 12 fans to case
Usually with screws. There are also rubber pull through things you can use in place of screws.
https://sgcdn.startech.com/005329/media/products/gallery_large/FANSCREW.B.jpg
https://ae01.alicdn.com/kf/HTB1NAHpRpXXXXaeXpXXq6xXFXXXU/Gdstime-10000-Pcs-Lot-45mm-Shock-Absorption-Easy-Fixing-less-Noise-PC-font-b-Fan-b.jpg
For the screws, I suggest screwing them into each corner of the fan you intend to use prior to placing it in the case. Since the screws create threads as they go, it can be difficult to do it in place.
Hard to put in words, but the rubber/silicone mounts are pulled through the case and through the fan until the wide part snaps into the fan's screw hole.
