How do you put liquid or water into corsair h100i?
Why would you put liquid inside an all in one liquid cooler? Thats why its called an all in one, it already has the liquid sealed up in the product.
Thank you so much!
All of the Corsair H series all-in-one coolers are sealed loop systems. There isn't anyway for the end user to service the unit without voiding the warranty. These AIO units are typically rated for ~5 years of operation with the contained liquid. I imagine after 5 years the unit will continue to work if the motor doesn't fail and if the radiator/fittings don't corrode. The tubing and fittings used on those units are very very low leakage/evaporation designs.
