How does a 6 pin to dual 8 pin work?
new-gamer
52
My question is simple and came into my mind suddenly, how it can work as the 6 pin cannot deliver the power of a 8 pin so how the converter works with a psu having a 6 pin connector which can only give 75w and we convert it into a 8 pin, it will surely fit in gpu's 8 pin port but will the 6 pin give 140?
It doesn't. Not well, anyway.
That's why we continually recommend against adapters like that. A PSU that lacks the proper connectors does not have enough juice to run a GPU like that.
Technically, you can use it if the card does not actually need all that power - some GPUs provide 8 pin connector, while in reality they pull significantly less than 150w from this connector. Regardless, this is not a safe practice in any case, and you better have PSU with required connectors.
